Alright, I'll see what I can spot in the code. Hang tight, I should have another version later.
edit 2: Looking again at the original code I copied, the value for the color is going into the 'B' channel, my recommendation is to try the 'B'
C++ code:
sample[count].a = 0;//val;
sample[count].c = 0;//val > 2048 ? true : false;
sample[count].intl_a = true;
sample[count].b = val;
sample[count].x = curr_x_pos + x_origin;
sample[count].y = curr_y_pos + y_origin;
count++;
In the future, I'll probably have this configurable in the GUI.
C++ code:
count++;
Wabbe
- Location: Novi, MI [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
This is with no TTL and the laser on at all times.
Here's what I have so far:
https://www.youtube.com/watch?v=FeOr5I3 ... kAak31HyzA
I made a change to put the intensity value in both the A/B channels. The C channel should be on when the intensity is above 1/2 value. You can use the same link as before to download it :
Please let me know the results. I'm going to make some more modifications to only scan the lit pixels in the image.
