I have updated the instructions for using the arduino driver software and added comments to the code listing on the site and in the software download to better explain the parameters in the driver software and what they are used for.
http://projectsinterestsandetcetera.com ... ectronics/
HL
Arduino based controller for dlp printer
Re: Arduino based controller for dlp printer
Just wanted to say thanks for explaining the code and what it all does, I'm sure it might help some others as well that are like myself and have zero understanding of how code is written or how to interpret it.
One last question, is there a way to slow the main lift compared to the return? The machine I am building that will be using your firmware will have a passive vat tilt and would be nice to be able to peel at a slow rate and return at a normal rate if that is something that can be done easy enough? If not I will just slow the whole process down.
Clinton
Clinton
johnrpm
I think it can be done with a slower feed, ie, Zxx.xx F20, then after separation Zxx.x F100.( example only)
mystamo
- Joined: Wed Feb 18, 2015 11:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
HTL..
Thanks for the FEP sheets. Very well packaged and came without any issues.
Also thanks for the firmware base that I was able to use in Arduino to control my SLA. Great job. A bump for software that people should be using to control their printers.
Regards,
Mo
Regards,
Mo
