Jajajaja, you beat me Clinton!!!
Google helps!!!
						First surface mirror, Aluminium, Glass or Acrylic?
				Excited4DLP
- Joined: Wed May 14, 2014 10:40 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: First surface mirror, Aluminium, Glass or Acrylic?
Does the thickness of a first-surface mirror change the quality of the reflection from the projector at all? firstsurfacemirror.com offers thicknesses of 1.9mm, 3mm, and 6mm.
				Excited4DLP
There really should be no need to brace even at 1.9mm, it's a piece of glass so if it's flexing there is a issue. I have no idea how it would flex in this kind of application though?
						- @A2
- Joined: Wed Apr 23, 2014 7:58 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
You're not placing a load on the mirror so probably the only issues are vibration, and heat distortion.  I would insulate the mirror from it's mount with double sided adhesive coated cork, and/or foam, with a few perimeter mirror clips if the bond fails.
I'm looking for a first surface mirror from a discarded rear projection TV.
Heat? How close do you think the mirror sits? Unless you run a double folded design no way is the mirror getting too hot, even then I very much doubt it. You could ask Edge he runs a double folded design and I didn't see any insulation on his mount, can see that being a issue in the least.
				Excited4DLP
