Hello guys.
My first attempt to print was a failure - it seems the entire build plate was cured. Check out the picture. I did a dry run without the tray and no resin and the leds were flickering. Is this normal? I wanted to give it another try but i cannot connect to the printer through the browser anymore.
Thank you in advance!
Jan
				malamen
- Joined: Sun Feb 12, 2017 10:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Have you noticed that platform cannot lift up
				malamen
i think you shod try to go to the local net on your PC and check out printer.If you cannot find it,allow the net to show you connected devices,And try to launch it from there.If it does not run i will give you the software update wich was given to me by james.By the way,i think they did not connect this board as it requares.There should be 5.5 volt but they give it 12 through resistor
				Rasp
- Joined: Sat Mar 25, 2017 10:51 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi everybody!
Attention, owners of KLD-LCD1260. Would you kindly provide me a foto or video of LCD panel during the printing job without resin tank and platform, please?
Thanks in advance, Alexander.
				Janowan
- Joined: Wed Mar 22, 2017 1:28 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
There you go! I also wanted to upload the picture for everyone else to see, because i need to know if it looks fine or if there is something wrong with the display.
				Rasp
Hi Janowan!
Thank you!
Might I ask you about publish a short video in topic?
						Thank you!
