				russiangems
The ribbon cable does a 90 degree turn and goes into the case and connects to the small circuit board. Now if this ribbon cable is broken you will need a new LCD display.
				malamen
- Joined: Sun Feb 12, 2017 10:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Has anyone used Nextdent or formlabs resin?I need adjasments for them, thanks
				mandrea
Good news on the front " Z axle ": I modified the shaft  with a pitch 2, I added a screw anti backlash with amazing result, no more waving effect ...
				Deaner3D
- Joined: Sat Feb 11, 2017 6:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
ok so which of you glorious bastards prepurchased the "Pro" version shipping in a couple weeks?
				Cabo
- Joined: Wed Sep 09, 2015 8:06 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi mandrea,
Can you tell me or link me to the parts to upgrade the lead screw and the backlash nut.
Thanks.
Thanks.
				mandrea
I modeled this 1 cm thick, to be placed above the engine, because the joint hit the end stop sensor
- VDNKh
- Joined: Tue Jan 24, 2017 7:27 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Anyone have ever tried FunToDo SnowWhite or DeepBlack resin with this printer?
