Thank you very much for the Russianarmy information. I talked to James, really was very considerate to me. I also found another link with the lowest value. Look this
https://portuguese.alibaba.com/p-detail ... 74576.html
- Joined: Sat Mar 26, 2016 11:23 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Sorry Russiangem I wrote wrong your name
fabioweno,
don't forget, that link you posted as additional shipping cost
the price from james has shipping already included.
- Joined: Mon Jan 12, 2015 2:52 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
You can also find it on Taobao.com, but I have no idea the additional hassles that adds. My friend purchased from taobao in china, but to send to other countries might be more complex. It was $443 or so, but I assume shipping is extra as well.
- Joined: Sun Dec 04, 2016 12:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
PIT,
can you share your step by step Raspberry configuration?
another big plate print.. had to tweak the print settings a little
5 base layers 72 seconds
normal layers 11 seconds
the print is a casing for my raspberry pi 2, the bottom en top part fit just perfect.. Yay
source raspberry pi case stl model:
post-curing now .. meaning.. it is a bottle with water waiting for some sunlight
and tomorrow there will be a strom.. so have to wait until we get some sun again
excellent results HP,
I'm waiting for the FTD industrial blend resin , because with other resins I can not get satisfactory results (probably this is due to the fact that they are not calibrated to react to 405 Nm)
