CW first run: Z-axis moves, but not on "home"
erenaud
Postby erenaud » Thu Nov 05, 2015 11:07 am
Hi all,
I am just trying to run Creation Workshop for the first time (again)
on a new hardware.
Everything seems to be fine, but when I press the "Z-home" button, the Z-axis does not move downwards to it's home position.
If I click Z -10, it doesn't move either.
If I click Z +10, it DOES move up,
and then down again if I press Z -10 again.
However it never goes further down as it was when I turned everything on.
What I am trying to do is configure the Z Endstop, and for this I need the Z-axis to move down first to position zero.
What's wrong here?
Thank you in advance for any help.
______________________
Etienne Renaud
Not quite 3D Printing, but somewhat similar:
tom-res
Re: CW first run: Z-axis moves, but not on "home"
Postby tom-res » Thu Nov 05, 2015 11:16 am
If you're using marlin, you'll have to disable your software endstops
check this site out for more help:
erenaud
Postby erenaud » Thu Nov 05, 2015 11:41 am
@Tom
It is indeed Marlin. I am using the firmware as downloaded from mUVe3d.net with the mUVe 1.5 DLP Hardware.
But I'll look into this.
Thanks.
Etienne Renaud
erenaud
Postby erenaud » Thu Nov 05, 2015 12:00 pm
The physical endstop "Z-" was not correctly wired. corrected it, now it works.
Thanks again.
Etienne Renaud
