First of all, one of those 2 objects was interrupted by a power outage, and the other correctly printed the rods, but I broke them off by accident...
For some reason I cannot solve 2 problems I've been having.
1) Creation Workshop can't get the timing right for the base layers and so I have to add a 1500ms dealy in the preslice otherwise it will start projecting the next slice before the build platform has made it all the way back to the bottom of the tank. Unfortunately, this is only an issue with the base layers and the other layers all sequence normally, but I can't seem to write a good If>Then code to get it to only delay on current slices <11, so my prints are taking 2 hours instead of 1.
2) Even though the projector is displaying the correct images, and as you can see I'm getting at least 3 of the 4 holes in the build, I'm getting some failure to cure for some reason on the bases of all of my prints. Help?
Thanks,
Tymmy
