By following the guide up to the point of importing your excel results into Rhino, I came across is this software
My results ranged from 0.76 to 3.0, I subtracted my results from 4 (to get the inverse of my results)
Then dropped the decimal point and dropped the last number (if more than 4) or added a 0 (if less than 4, unless its less than 1000), to turn them into milliseconds "ms" xxxx
This way your only looking for the difference between the different numbers, and what the numbers are i.e. UV level or Time, it doesn't really matter
Dan
Following the guide my grayscale mask for an Optoma HD26
Mask Builder Settings
Same data values, but output by the Garage Science software
Seems to be pretty consistent, just need to smooth out the colour transfer from the different value points and have the ability to load and save settings.
Dan
