hello Steve,
this one might be the key feature once we can print continuesly and as its used at almost every FDM printer, it would reduce print time by a very serious amount and even production costs due to less used resin.
Whats needed:
- selectable shell thickness of the part
- selectable bottom thickness of the part
- amount of support structure instead of full-material
I don´t know how much work would be involved in developing that, but i guess this could become crucial.
Making CW futureproof: Implementation of making parts hollow (with infillstructure)
Re: Making CW futureproof: Implementation of making parts hollow (with infillstructure)
Except you don't have to worry about liquid resin getting trapped in on a FDM machine. You would have to have a drain hole for every hollow. Intricate parts may have hundreds of these hollows.
Autodesk’s “Within” Could Generate Industrial Change
Posted Jul 20, 2015 01:00 pm
Autodesk introduced a new product called, “Within” that generates lattice structures within 3D models. It could change...http://www.fabbaloo.com/blog/2015/7/18/ ... -116537121
