Question about the Mask feature in Creation Workshop:
Will the mask be applied to the png export output (e.g. the directory of slice png files) or is it only applied to the screen image when Creation Workshop is controlling the printer?
The reason I ask is becuase the Kudo3D printer uses its own control software (which still sends Marlin GCode and controls a second monitor, but has more layer settings for exposure and lifting) and takes PNG files as input.
I'm trying to set up a mask and am not seeing it take effect in the exported PNGs, and I'm not sure whether I'm doing something wrong or if I need to use a different tool for this.
Mask - Project output only or also in png slice export?
Re: Mask - Project output only or also in png slice export?
My first thought would be to double check that your machine config has the enabled.
However, a quick skim of the CWS source makes it look like the Steve will have to chime in and confirm this, but it looks like you're SOL for now...
