Page 2 of 3
Re: Custom resolution option
Posted: Fri Apr 10, 2015 11:56 am
by miki71ita@libero.it
Here is the easy solution to use every microns output setup.... a CUSTOM DISPLAY... :
Posted: Fri Apr 10, 2015 12:07 pm
.. added by default!.. so you don't need to change anything in your code.. or not? I think so!..
Posted: Fri Apr 10, 2015 12:23 pm
Posted: Fri Apr 10, 2015 12:55 pm
OK..!!! I'm happy to help you in upgradeing your SUPER CreationWorkshop... because it's the best Slicer for me...!!! good job man..! (( I made what you told me before, and it's ok (look at screenshot).. but the problem is when I add the Display and I click the "Apply" button, because all my input changes to the old sizes by default..! and so it's a good idea to upgrade the new version as I showed you before. Bye and good job!..).
Posted: Fri Apr 10, 2015 3:25 pm
..I'll be very happy to be a beta-tester of your addon and to make a lot of test on my "3DPlotter" using more microns setups, of course.... if you want, use my email (
miki71ita@libero.it) to send me the only "CreationWorkshop.exe" after your upgrade. Bye!
Posted: Fri Apr 10, 2015 3:48 pm
Add in a monitor to your configuration and save it, then you can modify that display to be the size you need it to be.
Posted: Fri Apr 10, 2015 3:59 pm
Do you mean like this?.. :
Posted: Fri Apr 10, 2015 4:04 pm
..ok, I have 1000 microns, or microns I want (before clicking the "Apply" button!).. but.. Width and Height are always disabled, of course.. and so I need every time to edit manually the config files..! and so I think that the "Custom" solution by default it's much better....! Then I'll wait for the next CreationWorkshop upgrade....!
Posted: Fri Apr 10, 2015 4:13 pm
This is the best solution...
Posted: Sat Apr 11, 2015 3:39 am
