Would it be an idea to make things that are configurable, like slice thickness, Exposure time, dipping vars etc. available on the concept of a time line.
I am new to this whole 3d printing world, but i did notice some parts could use more exposure while other could use less. Even layers could be thicker to speed up printing where a model doesn't needs much detail or when the next slice is identical to the previous.
Simply said every slice could have the options that are available in the slicing profile configuration.
Time /slice line printing
Re: Time /slice line printing
That's an interesting idea. CW can already change properties based on the slice number, which is sort of what you're describing.
r255
- Joined: Tue Jan 27, 2015 6:22 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Perfect!
Ill have a look at the manual, but a easy way to set ranges would be a great addition i guess.
