I doubt this is the issue, but I made the dumb mistake of adding my configured port in the **projector serial port** box instead of the correct driver box in CW. Worked via serial port, not via CW, so I found I had just input my values to the wrong place!
Can you send Gcode commands via the manual Gcode terminal in CW?
Also, make sure your connection settings are correct in CW (baud rate, etc). Could you show us your CW settings for your serial port, please?
CW 36/41 crashes immediately on Mac OS X. Workaround?
Re: CW 36/41 crashes immediately on Mac OS X. Workaround?
It doesn't look like you're connected. Are you clicking the 'Connect' button at the top? What messages pop up after connecting?
Well, I'm glad you got it figured out. I knew it must have been something simple.
Like I tell people at my dayjob, I would much rather it be something easy that something impossible
