Slider system intermitent
firecardenal
Postby firecardenal » Thu Nov 20, 2014 9:57 pm
Hi guys, hi Steve.
I have a top-down printer with slider system.
In the g code, I have a line like this.
G1 X 120 F 3500
G1 - X 120 F 3500
This is done in each layer
But actually it is not necessarily so, and I'd like to turn this feature every 3 to 5 layers.
How I can achieve that?
Thanks for all.
regards
Re: Slider system intermitent
Postby PacManFan » Fri Nov 21, 2014 12:49 am
Read the new User Manual here: . I have a section on Gcode Pre-processor commands and how to achieveGCode commands that can occur on various slices or slice intervals. You can use the modulus operator '%'.
firecardenal
Postby firecardenal » Fri Nov 21, 2014 4:50 am
Thanks Steve.
So, if I want to activate the y axis every 4 slices, then :
{$CURSLICE%4==0?G1 Y124 F3000:Y0}
G1 Y-124 F3000
Its works very well, but if I do not want to take the first layers GUI in consideration ?
firecardenal
Postby firecardenal » Fri Nov 21, 2014 3:11 pm
I managed to run intermittently slide system but I need the first layers (that are used to attach to the building platform), work with regularly and after these layers, passing intermittently.
I appreciate any help.
Postby PacManFan » Fri Nov 21, 2014 6:43 pm
firecardenal
Postby firecardenal » Fri Nov 21, 2014 6:58 pm
Ok Steve.
********* Lift Sequence ********
G1 {$SlideTiltVal != 0? X$SlideTiltVal:} Z($ZLiftDist * $ZDir) F$ZLiftRate
G1 {$SlideTiltVal != 0? X($SlideTiltVal * -1):} Z(($LayerThickness-$ZLiftDist) * $ZDir) F$ZRetractRate
{$CURSLICE%3==0? G1 X124 F3000:}
G1 X-124 F3000
;<Delay> %d$BlankTime
firecardenal
Postby firecardenal » Fri Nov 21, 2014 7:07 pm
another question. Can you print the first layers of different thicknesses? for example, the first three layers of the GUI at 100 microns and 25 microns the rest?
how_eee
Postby how_eee » Fri Nov 28, 2014 10:03 am
Postby PacManFan » Fri Nov 28, 2014 11:55 am
how_eee
Postby how_eee » Sat Nov 29, 2014 6:58 am
Your can program it this way. Slice model twice. Take n thicker slises for first layers and rest slices for another layers.
