Page 3 of 4
Re: acer h6510bd serial commands - SOLVED
Posted: Mon Feb 16, 2015 2:37 pm
Use an ascii to hex converter. Also, you'll have to manually add a CRLF to the end .
Posted: Mon Feb 16, 2015 5:43 pm
by vonhellsing
not wanting to abuse the patience, I have no idea how to do this kkkk
i just put CRLF or have some code
can u helpe me ?
cheers!
angelini
Posted: Mon Feb 16, 2015 5:46 pm
by Scatterplot
CRLF means Carriage Return, Line Feed. See the following table:
http://www.asciitable.com/You can see that Carriage Return is hex 0xD and Line Feed is 0xA. I'm not sure what format exactly you need your hex codes in, but I assume it's two ASCII letters per Hex character, so at the end of your converted string just add 0D0A (those are zeros, not O's).
Posted: Mon Feb 16, 2015 5:58 pm
by vonhellsing
I find this factory manual, with this codes IR codes, ASCII, and some examples.
I don't have idea i need put on and off in creation workshop
cheers!
angelini
Posted: Mon Feb 16, 2015 6:20 pm
according to the pdf, you should just be able to send '02'
Posted: Tue Feb 17, 2015 5:45 am
by neurofun
first make sure you select "projector control" in "configure machine".
then click "edit commands" under projector control in the control window.
these are the on off commands for benq projectors:
<CR>*pow=on#<CR>
0D2a706f773d6f6e230D
<CR>*pow=off#<CR>
0D2a706f773d6f6666230D
Posted: Tue Feb 17, 2015 5:57 am
by vonhellsing
Wow thx man!!
Posted: Tue Feb 17, 2015 8:42 pm
by vonhellsing
Posted: Wed Feb 18, 2015 6:54 am
by neurofun
i use those codes for a benq w1070+ and they work fine.
check your baud rate, for the w1070+ it is 115200baud.
Posted: Fri Feb 20, 2015 8:22 am
by vonhellsing
