Page 2 of 4
Re: New Creation Workshop RPi Host
Posted: Tue Jan 20, 2015 2:42 pm
by danielm
Hi ergobot, how is the work going?
Could you please provide some usage instructions?
Posted: Tue Jan 20, 2015 2:58 pm
by ergobot
The pi version is not working at the moment. Will keep updates going.
Working to resolve final issues when testing the rpi conroller.
making the initial deployment easy
rxtx lib path
cleaning up html
few other misc fixes
In addition to this, we have more added and need to retest. We are targeting the raspberry pi at the moment.
The latest is available at:
https://github.com/area515/Creation-Workshop-Host/The commands to download the build and install are located in the file named "networkinstall.sh".
Posted: Fri Feb 13, 2015 3:21 am
by ps_bond
Out of interest, what are you using for bug tracking?
Only a minor one - the network install script tries to download an older version of the zip which isn't on Git. I'll be able to do a bit more testing once the printer arrives...
Posted: Fri Feb 13, 2015 5:20 pm
by ergobot
Posted: Sat Feb 14, 2015 3:07 am
by ps_bond
Ah, cool. Couldn't see it for looking.
Posted: Sun Mar 08, 2015 5:07 pm
by sloxd
Hi. I am trying to setup my printer with Raspberry Pi and CW RPi Host. I wonder if there is any manual how to wire RP and other stuff? I guess RP still needs some Arduino/RAMPS to drive stepper? Otherwise I saw that you need help with testing... I would be glad to help
Posted: Fri Mar 20, 2015 5:01 am
by how_eee
To install use this:
if you want to install it than take a look at this install guide :
https://github.com/WesGilster/Creation- ... lnotes.txt networkinstall isn't used anymore to install.
Now it works.
Posted: Fri Mar 20, 2015 5:30 pm
by PomeroyB
Posted: Fri Mar 20, 2015 10:18 pm
by adambx
I've just bought a RPi 2, so i will try out the Host very soon. Would be a pretty neat solution if i come up with a web interface
Cheers^^
Posted: Sat Mar 21, 2015 5:26 am
by ps_bond
What's the current status of this?
Installed the latest update yesterday; it runs, but I can't seem to get any response from the printer.
Using the autodetected printer, /dev/ttyUSB0, display :0.0; started the printer and clicked on enable motors. Tried driving the Z axis and there's no visible response. I haven't tried uploading a print to it yet as if I can't get the motor to drive there seems little sense in trying a more complex use case.
Is there a debug output that can be enabled?
