i´m trying to control my Projector with the RS232 Port. I have a RS232 to USB adapter.
My problem is to generate the right code, i have try already to insert the Code for the Manual but CW does´t accept it.
as an example i have try to insert the code to turn the Projector on
0x06 0x14 0x00 0x04 0x00 0x34 0x11 0x00 0x00 0x5D
Manual
ViewSonic PJD7820HD Projector Command
- Joined: Sun Jul 06, 2014 9:07 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: ViewSonic PJD7820HD Projector Command
It works, thank you again
