OS X Status?
Re: OS X Status?
Mono is not an application per-se, but it's more of a set of libraries that will allow you to run applications. I think if you right-click on the CreationWorkshop.exe file, there should be an option to start it using Mono.
- Joined: Thu Aug 14, 2014 8:32 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: OS X Status?
Maybe you have an extension of some kind that lets you do that? As far as I can tell with my new mono install it needs to be done from the Terminal.
<terminal prompt>$ mono <drag the .exe into the window>
e.g.
Garden-of-Pure-Ideology:Libraries elicurtz$ mono /Users/elicurtz/github/UVDLPSlicerController/UVDLP/Software/PC/UV_DLP_3dPrinter/UV_DLP_3D_Printer/bin/Debug/CreationWorkshop.exe
e.g.
- Joined: Mon Aug 18, 2014 12:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: OS X Status?
Alright! I got it to work But like said before quite a few bugs...
Re: OS X Status?
I had to change a few of the library references to even get it to build, so I'm not surprised the precompiled version didn't do much. Unless you're eager to pound your head against code I think you should consider the OS X version nonfunctional at this time. I'm going to do some work on fixing it and/or splitting out the UI from the actual printer control parts.
- Joined: Tue Dec 22, 2015 2:31 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
