I connected two stepper motors to an Arduino Mega 2560 with a Ramps 1.4 shield. (one for Z, one for X)
After uploading the Ramps Testcode as it can be found here http://reprap.org/wiki/File:RAMPSTestCode.pde
the steppers work fine, they are turning nicely in both directions, also the optical endstops do seem to work.
However once I put either Marlin or Sprinter as a firmware on the arduino, just nothing happens with Creation Workshop.
This is what I tried/did already:
- Define in Marlin/Sprinter And CW the baudrate to be 115200,
- correctly define the Com Port to COM3
- pressed the "connect" icon which to the right of the floppy disk icon
- I switched the "Motors" switch to the ON position
- I tried to send Gcode manually (G0 X12) or (G1 X12) - code is confirmed because it moves to the "sent" area, but no response and nothing moves
- I tried to press the XYZ direction buttons - nothing moves
It can't be the hardware, since the Ramps Testcode makes everything move - I must be doing something terribly wrong, but what?
can anyone help ?
Ramps Testcode works, CW does not, what to do?
Stephen,
Bachelor Student at LOOXIS France
Re: Ramps Testcode works, CW does not, what to do?
The test code is to test to make sure the RAMPs hardware is configured properly, you'll still need to actually configure values in the configuration.h in the firmware for Sprinter/Marlin. Pay close attention to the endstop settings. If they are mis-configured, the motors may not turn at all, or only turn when an endstop is triggered. 90% of the time, that's they problem.
Also, in CW, open the message window at the bottom (under view options in the 3d view) . Also in the manual control window, show the gcode window. When you send a command, it should show the command response. If you're not seeing 'ok' as a response to GCode commands, then there is a communication issue.
Yes Exactly what Steve says it's your end stops that are causing your issues. The Z axis or any other axis you have on your machine needs to be homed before it will function properly.
I am just going to upload my modified Marlin firmware to DB, I will post the link when it's up.
Clinton
Clinton
Clinton[/quote]
I am also happy to test it the modifed Marlin firmware. Can also you send me?
Lajos
Clinton[/quote]
Lajos
Sorry... I found it already
- Joined: Sun Mar 08, 2015 4:25 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Is it possible to run Marlin firmware without endstops? At the moment I have working setup with Sprinter but I would like to add servo shutter so I guess I need Marlin. But I just can't make it work....
It works now!
I disabled temperature sensors.
#define TEMP_SENSOR_0 0 // 0 instead of 1!!
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 1
