Version 21 is available through here:
						Creation Workshop RC9 - Not on GitHub!
Re: Creation Workshop RC9 - Not on GitHub!
Awesome!  Does this release include fixes for the image display delay problems some of us have seen?
Shane
									Shane
Research Chemist
If you're feeling REALLY bold, try version 28, now with the image delay fix, additional slicing ink/resin parameters, and a few other nice fixes. Now, mind you, this version was a test version I had originally made for Uncia support (still only kinda working), but the rest of the build still works as normal. (although you may have to create new machine /slicing profiles)
It also has an experimental 'Exposure Tester' built in to help users determine the proper exposure of models by exposing different portions of the model with different exposure times.
				Glacian22
That exposure testing mode sounds interesting, I'll have to play around with v28, thanks!
UPDATE: I can verify this does take care of the image delay issue I've had. I would expect it'll work just as well for the others that saw this problem!
Research Chemist
				Batuta
- Joined: Thu Jul 03, 2014 2:47 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Just wondering about diferent thickness in the same model.
Research Chemist
				MrBaz
- Joined: Sun Oct 12, 2014 9:55 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Maybe I'm missing something that is right out in the open, but how do I generate supports?  I have an older beta 13 version that generates supports, but the newer ones I've downloaded don't have the option of generating supports.  Am I missing something?
EDIT: Nevermind, I'm an idiot. I just needed to click on the "+" button.
