where to buy the hardware for DIY 3d scanner
1. No illegal activity
milo3dprinter
Postby milo3dprinter » Sun Aug 21, 2016 6:53 am
The cheapes way that you can diy your 3d scanner base on David software.THE TOTAL COST TO MAKE DAVID 3D SCANNER UNDER 1.000$
Hardware for DIY David 3d scanner for the cheapest way will fit with
Newest David 5.o with 2 camera
David pro 4.5.2
David laserscanner 3.10.4 .
supply hardware for DIY 3D Scanner.
Option 1 : 1 projector silce,1 complete camera,camera slice with lens for DIY David 3D scanner version 3 and 4 for only 250usd .USE FOR DAVID 3.10.4 AND DAVID PRO 4.5.0
Option 2 : 1 projector silce , 2 complete camera,camera slice with lens for DIY David 5.0 with 2 camera for 420 usd .USE FOR DAVID PRO 5.0 WITH 2 CAMERA
All the items is free shipping to worldwide
Contact to :
Website : milo3d.com/en
Email : milo3dprinter@gmail.com
PAYPAL ACCEPTED
PROJECTOR SLIDER IS DESIGN TO MOUNT ANY KIND OF PROJECTOR.I USE THE ACER K132 PROJECTOR
360 DEGREE PICTURE OF THE COMPLETED 3D SCANNER
http://megavisor.com/en/view/a53ad233-1 ... 399c829d89
VIDEO TO SHOW YOU THE SCANNER IN SETUP,CALIBRATE AND WORKING :https://www.youtube.com/watch?v=gxLYFgkwq7k
here is the "user gallery" with thoundsands completed file make from DAVID 3D SCANNER http://www.david-3d.com/en/news&community/usergallery
The hardware you will received Contents:
-Industrial 3MP USB 2.0 camera with high quality 6mm lens
-The camera supply the high fps
.12.67fps at 2048 x 1536 size(3.0 mp)
.19.28 fps at 1920 x 1080 size
.20.04 fps at 1600 x 1200 size
.27.97 fps at 1280 x 1024 size
.44fps at 1024 x 768 size
-Camera and projector slider
-500mm 20x40mm aluminum profile
-Some calibration printed
-Cable
BENEFIT:
You can get the professional david 3d scanner under 1000$
-The projector and camera are always at same angle as projector
-Much easier to set up camera! just put projection on to object and focus, set angle you want on camera mount ( about 25° to 30° ) then slide camera so you have projected image in view, focus camera, lock everything up, move object put calibration panels at same position, calibrate
-What you need only the projector used or new from 150-300$
This advanced model enhances the well proven structured-light-technology with a way better handling. Never before it has been easier to adjust a 3D-scan-system on scanobjects taking different terms and various scanobject sizes into account.
The scanner is mobile and can be positioned easily in front of the surface to be scanned.
A single click in the well proven DAVID software starts the scanning process and a few seconds later the digitised 3D model appears on the screen – even the colours of the object can be optionally captured and reproduced in the resulting scan!
You are able to scan all of the sides of the object in succession and subsequently render an enclosed 360° model.
The 3D model can be exported to standard 3D file formats (such as OBJ, STL and PLY) and processed in other applications.
Specification
Scan size: 60-500 mm
Resolution/Precision: Up to 0,05% of scan size (up to 0,05 mm)
Scanning time: One single scan within 2 seconds (or up to ~10 seconds, depending on settings and computer speed)
Mesh density: Up to 2,300,000 vertices per scan
Export formats: OBJ, STL, PLY
Requirements
Required
Standard-PC (32/64 bit – Windows Vista, 7, 8, 10)
3D graphics adapter
Available VGA or HDMI port
Two available USB ports
Recommended
Dual core 2 GHz CPU
64 bit Windows
8 GB system memory
3d graphics card (e.g. NVIDIA GeForce or ATI Radeon) with 1 GB RAM or more
USB 2.0
Milo3dprinter supply the complete 3d printer ,3d scanner and accessories...
