DIY David 3d scanner for the cheapest price under 1.000$
1. No illegal activity
milo3dprinter
Postby milo3dprinter » Wed Jul 06, 2016 12:11 am
this is the cheapes way that you can diy your 3d scanner base on David software.THE TOTAL COST TO MAKE DAVID 3D SCANNER UNDER 1.000$
the hardware is for sell 500$ with free shipping to worldwide.PAYPAL ACCEPTED
PROJECTOR SLIDER IS DESIGN TO MOUNT ANY KIND OF PROJECTOR.I USE THE ACER K132 PROJECTOR
here is my website link
360 DEGREE PICTURE OF THE COMPLETED 3D SCANNER
VIDEO TO SHOW YOU THE SCANNER IN SETUP,CALIBRATE AND WORKING :
here is the "user gallery" with thoundsands completed file make from DAVID 3D SCANNER
the hardware you will received Contents:
-Industrial 3MP USB 2.0 camera with high quality 6mm lens
-the camera supply the high fps
.12.67fps at 2048 x 1536 size(3.0 mp)
.19.28 fps at 1920 x 1080 size
.20.04 fps at 1600 x 1200 size
.27.97 fps at 1280 x 1024 size
.44fps at 1024 x 768 size
-Camera and projector slider
-500mm 20x40mm aluminum profile
-High quality tripod
-some calibration printed
-cable
benefit:
you can get the professional david 3d scanner under 1000$
-the projector and camera are always at same angle as projector
-much easier to set up camera! just put projection on to object and focus, set angle you want on camera mount ( about 25° to 30° ) then slide camera so you have projected image in view, focus camera, lock everything up, move object put calibration panels at same position, calibrate
-what you need only the projector used or new from 150-300$
This advanced model enhances the well proven structured-light-technology with a way better handling. Never before it has been easier to adjust a 3D-scan-system on scanobjects taking different terms and various scanobject sizes into account.
The scanner is mobile and can be positioned easily in front of the surface to be scanned.
A single click in the well proven DAVID software starts the scanning process and a few seconds later the digitised 3D model appears on the screen – even the colours of the object can be optionally captured and reproduced in the resulting scan!
You are able to scan all of the sides of the object in succession and subsequently render an enclosed 360° model.
The 3D model can be exported to standard 3D file formats (such as OBJ, STL and PLY) and processed in other applications.
Specification
Scan size: 60-500 mm
Resolution/Precision: Up to 0,05% of scan size (up to 0,05 mm)
Scanning time: One single scan within 2 seconds (or up to ~10 seconds, depending on settings and computer speed)
Mesh density: Up to 2,300,000 vertices per scan
Export formats: OBJ, STL, PLY
Requirements
Required
Standard-PC (32/64 bit - Windows Vista, 7, 8, 10)
3D graphics adapter
Available VGA or HDMI port
Two available USB ports
Recommended
Dual core 2 GHz CPU
64 bit Windows
8 GB system memory
3d graphics card (e.g. NVIDIA GeForce or ATI Radeon) with 1 GB RAM or more
USB 2.0
CONTACT TO US :
webstie: milo3d.com/en
email :milo3dprinter@gmail.com
skype :cuongtran626
facebook :milo3dprinter
Milo3dprinter supply the complete 3d printer ,3d scanner and accessories...
