So can it be any even number of projectors? Like one would be able to just scale up for any number of projectors? This could be a fun project to make a large format DLP printer .
Though just thinking about four 1080p projectors at 100 microns X/Y only gives a build area of 216mm by 384mm...not to mention that is at least $2400 in projectors (new and with a good deal).
Multiple monitors
Re: Multiple monitors
@AndersonHTa
Here's the link:
https://dl.dropboxusercontent.com/u/537 ... ltiMon.zip
1) 2 monitors are officially support with this version (more are possible with manual editing of a config file)
2) both monitors need to have the same output resolution
3) Horizontal or Vertical stacked layouts are supported.
If someone has a multi-monitor setup, please give this a try and let me know how it goes.
-S
-S
@AndersonHTa
Just to clarify a few things: I've been working with Demetris from OSRC on multiple monitor support. The multiple monitors are intended to be used in a stacked configuration either vertically or horizontally for 2 monitors. If 4 monitors are used, it can be laid out in a 2x2 grid. CW currently does not support overlaying multiple sub-pixel images over the same area to increase resolution in the same X/Y area.
-S
-S
- Joined: Wed Mar 05, 2014 3:48 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
