I've been working on a programming project since January and recently was able to finish it. I've created a grayscale generator that takes the relative exposure times for different portions of your build area and interpolates gray values for each individual pixel. It basically grays out high exposure areas so that everything has the same UV output across the build area. I'm still working on putting this into practice and testing it but I have made the software available for everyone to download so there can be a little more of a group effort getting this method put into practice.
If you are interested in this software you can go here to get a download link:
Tutorial videos for the software are located here:
Let me know what your think and if you find any bugs so that I can work to fix them.
-Garage Science
Grayscale Mask Generator
Garage Science
- Joined: Thu Mar 23, 2017 11:40 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I run a youtube channel devoted to 3D Resin Printing and other science projects.
https://www.youtube.com/c/GarageScience
