I've made some changes and small improvements on MonoWare. Please download and install the new version
MonoWare 0.1.005 -
https://www.dropbox.com/s/vucka027m9w1r ... 5.exe?dl=0The changes will be as below.
- Minor UI change for better visibility on Windows 10 & zoomed in text
- Support preview (watermark) during support placement
- Keypress "T" while object selected moves to object center
- Bug fixes during support generation
For LittleRP users and general Uno based printers, I've also configured firmware. Please download and upload it to your Uno.
Mono Firmware 05112017 -
https://www.dropbox.com/s/m7yf0q6a2skqy ... 7.hex?dl=0The pins that I've used for controlling the stepper and servo is as below.
Z-step pin: 4
Z-dir pin: 7
Z-limit pin: 11
Servo pin (shutter): 2
Fan control pin: 5
Pin 12, 13 are reserved for projector communication
- Other pins are not assigned in the version of firmware. Please let me know if you need further functionalities.
- You need to adjust the screw pitch inside Printer tab. AFAIK, LittleRP has 8 mm pitch, 200 steps per revolution, and 8 microstepping. So you can choose the three values 8.0 / 200 / 8. Please advise me this is not correct.
** Please note that the MonoWare and firmware is provided without any kind of warranty or I'm not responsible for any kind of damages of hardware or software system.
- mw_firmware.PNG (5.43 KiB) Viewed 18866 times
Nitros: Please make sure you can restore the firmware back into the original LittleRP firmware. You can do the firmware upload inside the MonoWare Misc tab if you have *.hex or Arduino IDE if you have source code (*.ino). Please check the COM port and correct Baud rate before uploading the firmware.
Jaidek: I've not implemented time period trial version yet. However you can give this version a try before releasing the time trial version. I have a plan to release the version when I implement auto-support.
Please leave a reply if you have problems and questions!
Yun
