did anyone try monkeyprint yet: opensource software for resin printers?
the source code can be found here:
Monkeyprint open source Software for resin printers?
Re: Monkeyprint open source Software for resin printers?
Can be used with LR printer?
- Joined: Mon Jan 09, 2017 4:08 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi there,
I'm the guy behind Monkeyprint
@Nitros: If you're talking about the LittleRP: I guess it can.
You are able to configure whatever G-Code you want to send at the start, during or at the end of a print, so basically any printer that accepts G-Code and does the exposure with a projector or LCD (in contrast to a laser scanning unit like the formlabs printers) can be controlled by Monkeyprint.
Also, I've been in contact with Brad Hill from LittleRP and he will be testing Monkeyprint sometime soon I guess.
There will be a website soon (still need to find some time to do it) that explains the features and how to set it up.
As of now, the documentation is a little outdated I'm afraid.
If there are any questions, feel free to ask
Best,
Paul
Best,
Paul
Thanks @robotsinhesun where can i download it? and in case could you please help me to set it up for LR?
You can find installation instructions here:
The hardware stuff is outdated, but in this blog post you'll find instructions for the setup with a g-code board:
I hope it works for you!
Best, Paul
Best, Paul
- Joined: Wed Mar 18, 2015 9:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Could you please tell me if Monkeyprint runs on RPi 3 ?
BR,
Daniel
BR,
Daniel
Hi Daniel,
depends on what you want to do: a) run Monkeyprint as a pre-processor for setting up your build platform, doing the slicing etc. or b) use the Raspberry Pi as a print server to control a printer?
For option A it would be necessary to have a second screen to display the GUI. One of the LCD options might work but the have a low resolution.
Option B is in the making and actually worked in some simple tests I did, but it's not stable yet and will require some more work.
Maybe you can tell me more about your plans and I can see how I can help you.
Best, Paul
Best, Paul
- Joined: Sat Jun 17, 2017 2:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I'm interested in giving it a go, will it be functional on windows 7 and marlin firmware?
