So I have used B9 and CW separately to create some supports on two different models but when I slice, I see that the supports are causing issues. In Meshmixer when I use inspector it shows the supports in pink (don't know what pink means) but it is differentiating it from the rest of the model:
When I try repair it in Netfabb is crashes. And when I try slice it the image shows up like this:
I can covert to solid in Meshmixer but it then degrades the quality of the part. Anyone know what is causing this and how I can fix it?
