Build Your Own SLA/SLS • nanoDLP - Raspberry Pi DLP Host Software - Page 4
Page 4 of 6
Posted: Wed Oct 21, 2015 2:02 am
by shahin
Posted: Mon Nov 02, 2015 12:42 pm
by Ray1976
Thanks! I've changed it and the strange thing is that I measure 1mm on the leadscrew but it's travel 1,2mm per turn. Result that 1cm = 1,2cm and 5cm turns out in 6cm. When I try to set it 1.2mm I get an fault answer that I must put the right number in. Are the imput numbers only whole milimeters?
It helps me when I can set 1/10th of a millimeter in.
Posted: Mon Nov 02, 2015 4:59 pm
by shahin
Posted: Tue Nov 03, 2015 10:20 am
by adambx
hi,
i've asked for a function some weeks ago to send custom serial commands instead of controlling the stepper driver. Have you looked into it? is it feasible?
Cheers^^
Posted: Tue Nov 03, 2015 5:11 pm
by shahin
Posted: Tue Nov 03, 2015 5:17 pm
by adambx
Posted: Wed Nov 04, 2015 4:29 am
by shahin
Posted: Sat Nov 07, 2015 5:52 pm
by adambx
i'm having trouble loading a zip file, it gets uploaded but the layer files are not recognized somehow. When i scp into the pi and look at the directories the "public/plates/" directory contains a folder with the plate ID, which is empty. The PNG files inside my zip are sequentially named.
.SLC input works
any ideas?
Posted: Sat Nov 07, 2015 6:07 pm
by shahin
Posted: Sat Nov 07, 2015 6:15 pm
by adambx
