hi guys.i m used ramps1.4+mega 2560 build my DLP print.just only have Z axis.
thanks for PomeroyB and PacManFan. i have change marlin.
line 62 in Configuration.h: #define MOTHERBOARD BOARD_RAMPS_13_EFB #define DEFAULT_AXIS_STEPS_PER_UNIT {500,500,500,500}
pins_RAMPS_13.h
have any other change?
thanks !!
does anyone share your marlin for ramps1.4 thank you very much.
can you tell me marlin change?
Re: can you tell me marlin change?
If you only have a Z-axis, that's all you should need to change!
dmc0750
- Location: JiangMen,CHINA [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thanks Pomeroy.
