Problem launching CW on Ubuntu Linux 14.10
jkao
Postby jkao » Sun Jan 04, 2015 2:40 pm
I installed the mono-complete package and tried launching both 1.0.0.41 and 1.0.0.36 on both Ubuntu 14.04 and 14.10 (same computer, I upgraded to 14.10 to see if it would make any difference).
In all the cases, the launch crashes with the following console output:
$ mono ./CreationWorkshop.exe
X11 Error encountered:
Error: BadMatch (invalid parameter attributes)
Request: 155 (5)
Resource ID: 0x4400040
Serial: 976
Hwnd: Hwnd, Mapped:False ClientWindow:0x4400040, WholeWindow:0x440003F, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x4400036, WholeWindow:0x4400035, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x4400034, WholeWindow:0x4400033, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x4400032, WholeWindow:0x4400031, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x4400030, WholeWindow:0x440002F, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x440002E, WholeWindow:0x440002D, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x440002C, WholeWindow:0x440002B, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x440002A, WholeWindow:0x4400029, Zombie=False, Parent:[<null>]]]]]]]]
Control: UV_DLP_3D_Printer.GUI.Controls.ctlGL at System.Environment.get_StackTrace()
at System.Windows.Forms.XplatUIX11.HandleError(IntPtr display, XErrorEvent ByRef error_event)
at OpenTK.Platform.X11.Glx.MakeCurrent(IntPtr , IntPtr , IntPtr )
at OpenTK.Platform.X11.Glx.MakeCurrent(IntPtr display, IntPtr drawable, ContextHandle context)
at OpenTK.Platform.X11.X11GLContext.MakeCurrent(IWindowInfo window)
at OpenTK.Graphics.GraphicsContext.MakeCurrent(IWindowInfo window)
at OpenTK.GLControl.MakeCurrent()
at OpenTK.GLControl.OnHandleCreated(System.EventArgs e)
at System.Windows.Forms.Control.WmCreate(Message ByRef m)
at System.Windows.Forms.Control.WndProc(Message ByRef m)
at System.Windows.Forms.ScrollableControl.WndProc(Message ByRef m)
at System.Windows.Forms.ContainerControl.WndProc(Message ByRef m)
at System.Windows.Forms.UserControl.WndProc(Message ByRef m)
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage(Message ByRef m)
at System.Windows.Forms.Control+ControlNativeWindow.WndProc(Message ByRef m)
at System.Windows.Forms.NativeWindow.WndProc(IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.XplatUIX11.SendMessage(IntPtr hwnd, Msg message, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.XplatUIX11.CreateWindow(System.Windows.Forms.CreateParams cp)
at System.Windows.Forms.XplatUI.CreateWindow(System.Windows.Forms.CreateParams cp)
at System.Windows.Forms.NativeWindow.CreateHandle(System.Windows.Forms.CreateParams cp)
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message ByRef m)
at System.Windows.Forms.SplitContainer.WndProc(Message ByRef msg)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.RunLoop(Boolean Modal, System.Windows.Forms.ApplicationContext context)
at System.Windows.Forms.Application.Run(System.Windows.Forms.ApplicationContext context)
at System.Windows.Forms.Application.Run(System.Windows.Forms.Form mainForm)
at UV_DLP_3D_Printer.Program.Main()
OpenTK.Graphics.GraphicsContextException: Failed to make context current.
at OpenTK.Platform.X11.X11GLContext.MakeCurrent (IWindowInfo window) [0x00000] in <filename unknown>:0
at OpenTK.Graphics.GraphicsContext.MakeCurrent (IWindowInfo window) [0x00000] in <filename unknown>:0
at OpenTK.GLControl.MakeCurrent () [0x00000] in <filename unknown>:0
at OpenTK.GLControl.OnHandleCreated (System.EventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control.WmCreate (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.UserControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Stacktrace:
Native stacktrace:
mono() [0x4b73d8]
mono() [0x50f13b]
mono() [0x423d22]
/lib/x86_64-linux-gnu/libpthread.so.0(+0xfc90) [0x7f1bf2434c90]
Debug info from gdb:
[New LWP 12669]
[New LWP 12668]
[New LWP 12667]
[New LWP 12666]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007f1bf2434839 in __libc_waitpid (pid=pid@entry=12672, stat_loc=stat_loc@entry=0x7f1bf2f5f19c, options=options@entry=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
40 ../sysdeps/unix/sysv/linux/waitpid.c: No such file or directory.
Id Target Id Frame
5 Thread 0x7f1bef0ff700 (LWP 12666) "mono" sem_wait () at ../nptl/sysdeps/unix/sysv/linux/x86_64/sem_wait.S:85
4 Thread 0x7f1be1b60700 (LWP 12667) "dconf worker" 0x00007f1bf21502cd in poll () at ../sysdeps/unix/syscall-template.S:81
3 Thread 0x7f1be135f700 (LWP 12668) "gdbus" 0x00007f1bf21502cd in poll () at ../sysdeps/unix/syscall-template.S:81
2 Thread 0x7f1be07a7700 (LWP 12669) "mono" 0x00007f1bf24344fd in nanosleep () at ../sysdeps/unix/syscall-template.S:81
* 1 Thread 0x7f1bf2f377c0 (LWP 12665) "mono" 0x00007f1bf2434839 in __libc_waitpid (pid=pid@entry=12672, stat_loc=stat_loc@entry=0x7f1bf2f5f19c, options=options@entry=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
Thread 5 (Thread 0x7f1bef0ff700 (LWP 12666)):
#0 sem_wait () at ../nptl/sysdeps/unix/sysv/linux/x86_64/sem_wait.S:85
#1 0x000000000062f667 in mono_sem_wait (sem=sem@entry=0x982440 <finalizer_sem>, alertable=alertable@entry=1) at mono-semaphore.c:119
#2 0x00000000005aba15 in finalizer_thread (unused=unused@entry=0x0) at gc.c:1073
#3 0x000000000058e34b in start_wrapper_internal (data=0x25d6700) at threads.c:643
#4 start_wrapper (data=0x25d6700) at threads.c:688
#5 0x000000000062410d in thread_start_routine (args=args@entry=0x2562378) at wthreads.c:294
#6 0x0000000000633ef5 in inner_start_thread (arg=0x25d2910) at mono-threads-posix.c:49
#7 0x00007f1bf242d0a5 in start_thread (arg=0x7f1bef0ff700) at pthread_create.c:309
#8 0x00007f1bf215a77d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 4 (Thread 0x7f1be1b60700 (LWP 12667)):
#0 0x00007f1bf21502cd in poll () at ../sysdeps/unix/syscall-template.S:81
#1 0x00007f1bedbf9ee4 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007f1bedbf9ffc in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007f1be1b6827d in ?? () from /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
#4 0x00007f1bedc20925 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#5 0x00007f1bf242d0a5 in start_thread (arg=0x7f1be1b60700) at pthread_create.c:309
#6 0x00007f1bf215a77d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 3 (Thread 0x7f1be135f700 (LWP 12668)):
#2 0x00007f1bedbfa272 in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007f1be58c7ef6 in ?? () from /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0
#5 0x00007f1bf242d0a5 in start_thread (arg=0x7f1be135f700) at pthread_create.c:309
Thread 2 (Thread 0x7f1be07a7700 (LWP 12669)):
#0 0x00007f1bf24344fd in nanosleep () at ../sysdeps/unix/syscall-template.S:81
#1 0x000000000062342b in SleepEx (ms=ms@entry=20, alertable=alertable@entry=1) at wthreads.c:842
#2 0x000000000058efbe in ves_icall_System_Threading_Thread_Sleep_internal (ms=20) at threads.c:1224
#3 0x00000000410b6fcd in ?? ()
#4 0x00007f1bd8002540 in ?? ()
#5 0x0000000000e09e17 in ?? ()
#6 0x00007f1bd80025c0 in ?? ()
#7 0x00007f1be07a6b70 in ?? ()
#8 0x00007f1be07a6aa0 in ?? ()
#9 0x0000000000000000 in ?? ()
Thread 1 (Thread 0x7f1bf2f377c0 (LWP 12665)):
#0 0x00007f1bf2434839 in __libc_waitpid (pid=pid@entry=12672, stat_loc=stat_loc@entry=0x7f1bf2f5f19c, options=options@entry=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
#1 0x00000000004b7465 in mono_handle_native_sigsegv (signal=signal@entry=11, ctx=ctx@entry=0x7f1bf2f5fac0) at mini-exceptions.c:2299
#2 0x000000000050f13b in mono_arch_handle_altstack_exception (sigctx=sigctx@entry=0x7f1bf2f5fac0, fault_addr=<optimized out>, stack_ovf=stack_ovf@entry=0) at exceptions-amd64.c:908
#3 0x0000000000423d22 in mono_sigsegv_signal_handler (_dummy=11, info=0x7f1bf2f5fbf0, context=0x7f1bf2f5fac0) at mini.c:6769
#4 <signal handler called>
#5 0x0000000000000000 in ?? ()
#6 0x00000000403009dd in ?? ()
#7 0x0000000000000000 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted (core dumped)
Any idea if this is some kind of configuration related problem or what further info might be needed to diagnose this?
Re: Problem launching CW on Ubuntu Linux 14.10
Postby PacManFan » Sun Jan 04, 2015 3:31 pm
Thanks for posting this. I'll look into it. It looks like the OpenGL / OpenTK failed to make the context current.
crusoe
Postby crusoe » Thu Jan 08, 2015 5:06 pm
What is 3d card make, and what drivers are you using? The Opensource Noveau drivers for Nvidia are shit, the Opensource Radon ones are okay ( though the AMD ones are quite a bit more stable ). The included Intel drivers are quite solid.
jkao
Postby jkao » Thu Jan 08, 2015 10:41 pm
It's an NVidia Geforce GTS 450 running the NVidia proprietary binary drivers, version 331.113 currently on Ubuntu 14.10, and 319.60 when I was on Ubuntu 14.04.
MasterCATZ
Postby MasterCATZ » Fri Apr 03, 2015 6:57 pm
I just get a black screen in slice view mode
3D mode works
if I get time I will build direct from git
*edit*
and to just made a liar out of me it just worked then when I launched from cmd line
