Hello everybody,
I just made a top down DLP printer but it needs some tweaks.
I use a wiper to flatten the resin surface after the Z movement but now it's going in the 2 directions before each slide.
What I want to do is :
- project slice 1
- go Z -0.05mm
- go X -250mm
- project slice 2
- go Z -0.05mm
- go X 250mm
then slide 3 with X negative direction, slide 4 with X positive direction, etc.....
Is there any way I can program that in Creation Workshop?
Thanks in advance,
Jeoffrey
need some help for gcode programming
- Joined: Thu Jun 05, 2014 8:32 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: need some help for gcode programming
Thanks Steve,
I will try that tomorrow. For now the printer is busy printing a test.
I will post some pictures today or tomorrow.
Jeoffrey
Jeoffrey
Well Steve, It works very well.
Here you can see a video of it working :
yes, but the result was not good.
I still have to work on the printer
Inspired by your work and the potential of Steve's software, I managed to make my own version of flattened system.
Uncia DLP, flattened and cleaning system:
http://youtu.be/EKdUpJDOWYA
Very Nice! I'm really impressed by how much you've been able to improve your Uncia machine.
Hi Steve.
I can do it thanks to people like you, who help others.
Thanks.
Thanks.
