I've disabled the dropbox link, but you can still download from online store.
https://www.monoprinter.com/products/monoware-lite
This is because the online store automatically notifies all previous customers about a new update. Therefore you'll know about a new version as soon as it's available.
Yun
MonoWare Lite - Slicing and control software for resin printers
cooly
- Joined: Sat May 28, 2016 7:54 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: MonoWare Lite - Slicing and control software for resin printers
Minor update is available.
MonoWare 0.1.009 Revision Log
- Two tone surface normal colors to help determine right support placement
- Display resolution override for off-printer slicing
- All support points can be moved horizontally (Use this at zoomed in view)
- Some bug fixes
- Some bug fixes
Jaidek
- Joined: Mon Jul 04, 2016 11:00 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hey Cooly,
Is it possible to control the LittleRP2 without having to change its firmware? Right now I have it working with NanoDLP, but I'd like to try MonoWare control as well.
Corey
Corey
Jaidek
Hey Cooly,
Ack...it looks like Monoware Lite is crashing on launch on my machine after the Windows 10 Creative update. This update also affected Autodesk Print Studio. Any ideas? I've uninstalled and re-installed as well.
Thanks,
Corey
Thanks,
Corey
Jaidek
Hey Yun,
Yes, I have an unmodified LittleRP2. I'd love to give it a test!
Wow, launching from a shortcut on my second monitor did the trick.
Thanks,
Corey
Thanks,
Corey
cooly
I just need to implement Z-axis motion, so it should be easy to do so. You'll get notified when I update the MonoWare on my online store. I've also implemented flip copies of supports along x-y axis, so you will see this feature on next release too.
Glad to hear the trick works.
Yun
Yun
Jaidek
Hey Cooly,
Any chance of an undo system coming soon?
Thanks,
Corey
Thanks,
Corey
cooly
Undo/redo is on the list. I'll implement them in future release.
Yun
Yun
