Hi guys,
been reading about DLP for a while, on this forum and elsewhere.
Still one thing (actually many) that is not clear for me. Can we use partial infill with resin and DLP ?
Seems that most people use 100% filled or shelled, but can we use partial infill like in FDM ? To save on resin ?
I read that you cannot do it because resin cannot escape the inside of the part. But i'm having problem to picture this.
Let's say you want to print a cube at 50% infill, and your infill pattern is just a grid, superimposed at each layer. So you have square tubes inside your part, except the first 3 and last 3 layers. When your part is almost finished to print, before the last 3 full layers, the resin inside your part can escape, right ? If you do your last 3 full layers with the minimum resin in your vat, you would end up with a bit of resin inside the part, but not completely filled either, right ?
Or is it that resin cannot really escape due to capillary effect of these small square tubes ?
Surely i missed something here.
Partial infill possible ?
Re: Partial infill possible ?
hi Hugues,
you are correct about the capillary effect, the resin is just filled halfway into an object.
