I have put together a SLC to PNG converter program with pretty good Anti-aliasing, low memory usage, acceptable performance through utilizing multi-core architecture. After further performance improvements I am going to add it to nanoDLP in form of native SLC support.
I will appreciate any tips about the program.
For windows
For 64bit linux
SLC 2 PNG
jkao
- Joined: Sun Jan 04, 2015 5:42 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: SLC 2 PNG
Works like a charm, thanks!
elliotm
- Joined: Mon Dec 21, 2015 9:21 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: SLC 2 PNG
I'm new to this program, but could I use it to customize the layers for the model and then load it to nanodlp?
adamk
- Joined: Sat May 21, 2016 9:24 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: SLC 2 PNG
Shahin
Thanks for this program, works good and fast. However there is a huge problem..
Models that i slice in this program becomes mirrored in print.
Meaning, text and letters and design come out mirrored as if reading in a mirror.
I cant get my head around why this happends.
Maybe its the software for the old miicraft i have that is the culprint. Perhaps the old slicer software (that uses skeinforge inside) is mirroring the slices and then the printer softer mirror it back into correct.
Therefore i need to ask you if you are Sure your software does not mirror the models ?
shahin
- Joined: Fri Nov 21, 2014 4:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: SLC 2 PNG
What's your input format? I have not got similar report, as it is usually very easy to flip view using the projector options or display settings.
adamk
Re: SLC 2 PNG
I have an old black miicraft so im using their "newer" software to slice into .slc
But since the printer software accepts .idx with all the png slices im using your SLC2PNG to extract the pngs.
This old miicraft uses a tiny pico projector och really primitive software so there is no mirror options available.
Is it possible for you to edit the slc2png to mirror the pngs for me? ;;;)
Or if you know of an free slicer that can make easy supports And slice into custom resolution png´s (768x480)
maxjewels
- Joined: Mon Nov 28, 2016 1:22 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: SLC 2 PNG
I have your own printer and I use your own programs,
and to solve that problem i do mirroring from rhino before inserting it in the "MiiUtility" program
