Yesterday I had my first run with latest Creation Workshop connected to Smoothieboard (default settings).
Manual controls work fine: Z movements were accurate.
When starting the job, it sends the first layer and freezes (time keeps running in the top right corner, but nothing happens) when Z starts to go up.
If I then don't stop to job, but go to manual control to move Z up - it sends the second layer...
Also tried with older Creation Workshops - same result.
Using the settings recommended for LittleRP https://vimeo.com/108978676
Any ideas?
						Only 1 layer printing
				jarno
- Joined: Mon Jun 29, 2015 6:33 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Only 1 layer printing
At the moment we are working 12 - 14 hour days...
Sunday is probably the soonest I can answer your questions.
Thank you
Thank you
