Problems with Acer X1173 and Makerjuice G+
General support for the Uncia printer
polbo
Postby polbo » Wed Oct 07, 2015 2:21 pm
Hi guys,
ssorry for my English... I don't speak English very well.
I've a Uncia DLP printer witn Acer X1173 projector. Last month I bought a Makerjuice G+ red resin.
I'm not able to have a good print quality and i understand which is the problem. In the internal menu, I set the projector with standard video propreties. Resolution is 1024X768.
My CW configuration is:
Slice thickness: 0,1mm
Exposure time per Layer: 6000ms
Bottom Layers Exposure time: 10000ms
#layers: 3
Enable Anti-Aliasing: activate (1.5)
Export images & GCode: activate
Lift and Sequence time: 10600ms
Z lift distance: 5mm
Build direction: bottom up
Z lift speed: 50mm/m
Z lift retract speed: 100 mm/m
Slide/tilt value:0
Can you help me?
James
Re: Problems with Acer X1173 and Makerjuice G+
Postby James » Fri Oct 09, 2015 1:04 am
Can you take a photograph of the print quality so we can see what the problem is?
polbo
Postby polbo » Fri Oct 09, 2015 12:43 pm
I hope you can see photo..
James
Postby James » Sat Oct 10, 2015 1:04 am
That's an excellent image, but I have not seen that print error before. Anyone else have any ideas?
polbo
Postby polbo » Wed Oct 28, 2015 2:52 am
Anyone else?
