Hi all!
Using waxcast and encountering this issue on uneven builds. It also happens on B9 Yellow so must be a hardware issue.
Got any ideas on more accurate builds?
You can see the wavy bottom of the halo collet. I've noticed this on other prints too.
Uneven build issues.
Re: Uneven build issues.
You should be able to solve this issue by tilting a few degrees on X or Y your model , just consider the first layer of the halocollet is/are very thin so it remain flexible , when you lift/peel and go back on you vat floor the first layers ( 1-3 depending on you layer thickness ) will be very easy to deform and keep some extra resin in between that will be cured ...
other option is to give a long settle time before exposure on those critical/sensitive layer.
