Build Your Own SLA/SLS • LittleRP2 Information - Page 7
Page 7 of 9
Re: LittleRP2 Information
Posted: Fri May 05, 2017 12:55 pm
by Jaidek
I believe 1.0.075 is the last free version that was released. What is on the LittleRP support page is 1.0.036.
Here's a link:
https://dl.dropboxusercontent.com/u/537 ... 0.0.75.zip
Posted: Sat May 06, 2017 12:44 pm
by cooly
Hi Brad,
Nitros asked me if MonoWare can work with LittleRP and I answered as below.
viewtopic.php?f=3&t=5934&p=17745#p17745
However writing here might be better to get the information since you're a manufacturer of the printer. If you think this is a good option for littleRP, I can configure the firmware to work with LittleRP and get feedbacks from your customers.
Posted: Sat May 06, 2017 3:51 pm
by goopyplastic
Posted: Mon May 08, 2017 8:33 am
by cooly
Thanks Brad,
So I understand the base board from Sparkfun is same as Arduino Uno in terms of pinouts and software, correct? If so, configuring firmware should be very easy. And I'd like to confirm that the pins used in LittleRP are as below.
Z-limit (P11)
Z-direction (P07)
Z-step (P04)
Is there any pins used that I need to consider?
Thanks.
Yun
Posted: Fri May 12, 2017 11:52 am
by goopyplastic
You might need to account for enable pin on the stepper drivers.
Posted: Fri May 12, 2017 2:53 pm
by cooly
Posted: Wed Jun 07, 2017 8:47 am
by cooly
Hi Brad,
Is LittleRP2 still using Grbl 0.8a? Seems like the commands are different between 0.8 vs newly released 1.1a.
Thanks.
Yun
Posted: Wed Jun 07, 2017 2:01 pm
by goopyplastic
All LittleRP's have shipped with .8a correct , there were some code changes causing issues with .9 for awhile so I never updated it. For folks to take advantage of the endstops they would need to go to a higher version though. I do use the standard GRBL pinout though and leave the bootloader on the boards (so xloader works etc) so updating the version of GRBL should be relatively easy.
Side note, I just uploated the self-source vat DXF's for the foam / fep. And linked to a guide showing which mounting posistions are for what projector on the base plate.
Posted: Wed Jun 07, 2017 4:56 pm
by cooly
Posted: Thu Jun 08, 2017 12:46 am
by goopyplastic
Since the LittleRP uses tr8*8, backdriving the axis manually seems more convenient / consistent than using homing for the most part. I think the homing switch included now is more of an option for if you are running a vat without an underplate or want it to home after the print is done to aid in resin draining.
The .9 problems were anecdotal (may have even been later version of the .8) but I believe seemecnc was having some banding issues and it was related to something that changed the motor control so I just kind of stayed away. Changing firmwares would make troubleshooting a little more complicated on my end having a mix of printer configs out there so it is a little selfish on my part as well :)
