procedure for establishing exposure times for new resin
jon_bondy
Is there a FAQ somewhere that outlines a procedure for figuring out the correct exposure time for a new resin?
radi2k
Re: procedure for establishing exposure times for new resin
Hi!
Check those instructables which can be adapted to your needs:
http://www.instructables.com/id/How-to- ... /?ALLSTEPS
radi2k
radi2k
The main things I do are to use the calibration cube stl I link off my support page.
I increase the cure time until the smallest column stands up on its own.
You can also use the piece to check how appropriate the resin / blocker is but checking for fillets where the columns attach to the body of the cube.
sechsteelement
- Joined: Tue Aug 23, 2016 5:55 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hallo,
@ goopyplastic, where I can find your support page?
Best Regards,
M.
Best Regards,
M.
cew
Another simple quick way to set the base exposure with a new resin or pigment is as follows:
Use the calibrationgrid.stl from http://www.littlerp.com/?page_id=55 Start with the recommended exposure settings. Check via the mirror the build platform is sitting flat on the dish. Print a few layers and have a look at the build platform:
If there is nothing on the build platform increase the exposure 150 - 200%
If there is some xy bleed on the build platform around the spots decrease exposure by 20-30%
If only the central spots are printing boost the exposure by about 15-20%
Also when scraping the dots off the build platform they should 'pop off' :
If they slide off too easily boost exposure by about 15-20%
If they are difficult to scrape off decrease about 15-20%
This only takes a few minutes.
Once this is done the upper exposure levels can then be fine tuned using the calibration cube as goopyplastic suggests above.
