I have got my CNC Shield recently. But no luck with making it work properly.
Z-axis is good, but Y (tilt-axis) is unreachable from CW.
I am using Creation Workshop RC54 for Tilt. As was said here , I had set some new GBRL parameters: $1 = 415.00 and $7 = 128.
Then, when I try to operate Z and Y axis from GBRL Panel software, they both are actually working fine. But, when I try to use control buttons in CW, I can't move Y-axis.
What did I missed?
How to configure firmware/software for tilt option?
DanOrgan
Re: How to configure firmware/software for tilt option?
It seems, CNC Shield is different from standard Little RP Shield. And the instruction was intendant only for Little RP.
I installed old 1.0.36 CW, and just enabled Tilt options in it. Then, connect my tilt driver to X axis. Now, it is moving!
