Hi! Little RP Maker Tilt Kit is out of stock now. And I am not good with soldering.
Is there any alternative for Little RP Shield, with more than one axis support?
Need Little RP Shield alternative
firecardenal
Re: Need Little RP Shield alternative
Im working with Arduino Uno and cnc shield. GRBL.
The other one its running with Mega and Ramps .Marlin.
I love working with Marlin.
DanOrgan
Firecardenal, thank you for advice!
Then, I'll just switch from Little RP Shield to Cnc shield.
If you ever need pre-soldered shields or tilt kits I can help directly no problem.
- Brad
- Brad
