Hi Guys, I just wanted to share with you this Build Plate I just modified, since I did this my adhesion failures have been reduced to 0%
http://imgur.com/iF62nYa
http://imgur.com/StHYj3F
drilled 1.5mm holes in an 5-5mm array. Then I grinded the surface with a broken drill bit.
Super adhesion free release bed
- Joined: Sun Feb 09, 2014 9:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Super adhesion free release bed
I've found that drilling holes into the build plate and hitting it with some 320 grit sandpaper (without scratching the surface this aggressively) is enough. Never had any adhesion issues.
