Printing flat surfaces z axis
- Joined: Fri Aug 07, 2015 1:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Printing flat surfaces z axis
Thanks a lot for all the help guys. I will try the rotation and will post the results asap.
Thanks once again, this is why I love this forums. It was such a simple solution, rotating on the z axis solved the question. It look perfect now.
- Joined: Mon Dec 07, 2015 2:57 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
The "exactness" of the lines makes me think it's a problem in the export of the file to a STL as STLs are a collection of triangles.
__________________________________________________________________________________
