FEP vat for the LittleRP?
AndersonTa
Re: FEP vat for the LittleRP?
Postby AndersonTa » Sat May 02, 2015 1:35 pm
Awesome work HTL!
Can't wait to buy one and try it out! Sign me up for one as soon as they can be available. :)
sgraber
Postby sgraber » Sat May 02, 2015 1:41 pm
Same here!
Research Chemist
HTL
Postby HTL » Sun May 03, 2015 2:33 pm
Torque wrench for tightening vat bolts:
sgraber
Postby sgraber » Sun May 03, 2015 8:38 pm
Any idea what the kit will cost?
Research Chemist
HTL
Postby HTL » Mon May 04, 2015 7:29 am
The craft foam is made of EVA:
Also, it does not give off chlorine gas when laser cut and it cuts quickly and cleanly.
HTL
Postby HTL » Mon May 04, 2015 7:36 am
I am trying to get the vat kit into the $65.00 - $85.00 range which would include the vat, 2 gaskets, 2 laser cut FEP sheets and the torque wrench. Spare parts and laser cut FEP will also be available.
sgraber
Postby sgraber » Mon May 04, 2015 1:47 pm
3D printing would really cut down on the waste of that one part in particular, but then again it would really slow down your part production time...
Research Chemist
cerriousdesign
Postby cerriousdesign » Wed May 06, 2015 2:26 pm
I would also buy one! Sign me up!
sgraber
Postby sgraber » Fri May 08, 2015 3:41 pm
Just throwing out an idea as a possible iteration / improvement on the already awesome design: you may want to not cut the central rectangular hole out of the "baseplate" part. This way *if* the FEP rips (which there's always a remote chance it could), the resin would be caught in the tensioning part and not run out onto the printer.
Research Chemist
dangre
Postby dangre » Fri May 08, 2015 4:15 pm
I've always wanted to know how much (if any) UV is filtered by Acrylic and this would be a good test if you did not cut out the center of the base and compare exposure times. It would help lessen sagging (more affected on big vats).
