Hi ,
after using my littleRP nearly a week I solved with your help a lot of questions and problems. Actually I have problems with CW and the x/y basic values (built sice) becaus I tried to print a ring and the ring is smaller then my CAD model.Is there anybody who solved this problem with an ACER P1500? x=72 / y=41.5 is definetally too small but how can I find the right values. Clear using the calibration too but how much tries must I do in the future to find out the right x and y values?
ACER P1500 x/Y values
Re: ACER P1500 x/Y values
Print a 20mm block, then measure the X/Y with a caliper. Enter the values you measure in the machine configuration using the 'adjust' button.
I have added some instructions for getting fine calibration values on the technical support page.
