Improvement Hack: End Caps for Build Plate (blocks resin)
Scatterplot
Re: Improvement Hack: End Caps for Build Plate (blocks resin
Postby Scatterplot » Thu Jan 22, 2015 7:20 pm
Looks great, though I'd guess that seam would be hard to clean and would trap resin, leading to drips and stains. Are you seeing any issues with that? I suppose you could always intentionally fill it with resin then expose it in the sun or a cure box until it solidifies and fills in all the cracks.
maurice
Postby maurice » Fri Jan 23, 2015 1:17 am
Aren't there any chemical reactions between the resin and the PLA?
I will try that aluminium tape to simply close the extrusion profile and see if it is practicable.
Postby PacManFan » Fri Jan 23, 2015 3:47 pm
Kattejuice
Postby Kattejuice » Sat Jan 24, 2015 1:02 pm
That looks really neat! I think I'll give it a try once I get my old FFF printer going again. Thanks for sharing!
maurice
Postby maurice » Mon Jan 26, 2015 5:22 am
This is my version with the aluminum tape.
So far it still sticks to the build plate.
