Hi Community, I happened across your forum quite by chance, saw a few pictures and now I am hooked.
I have a bit of experience in these kind of projects having in the past and quite fancy building my own printer.
Is there a single online resource anybody could direct me to as a primer in self-building which the community regards as a good resource?
I am looking for design choices and detailed build guides.
Finally I have read some (probably poorly informed) advice that the resins are very toxic? Is this the case, and what precautions if any do you guys follow?
Thanks, Al.
Greetings from Scotland
Alba
- Joined: Mon Jan 18, 2016 5:40 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Greetings from Scotland
I have just bought a working second hand Toshiba DLP Projector for about $40 delivered.
Specs:
Model TDP-D1
Display Technology DLP
Native Resolution 1024 x 768
Image Brightness 2000 ANSI lumens
Contrast Ratio 2100:1
Specs:
Model TDP-D1
