i recall someone testing a similar coating as base
based on this youtube clip
the test failed, resin was stuck between the nano structure and the buildplate, one of the possible reasons this happend is because you squish resin between the vat bottom and buildplate. causing this effect.
Kind regards,
Carbon 3D
Re: Carbon 3D
nice! best of luck keep us posted on the result ^^
- Joined: Wed Mar 25, 2015 4:54 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Carbon 3D
As posted before i am in communication with the company that can produce the Teflon Film in Europe.
Considering the very high cost of the material , can anybody give an advice of the thickness of the film , suitable to withstand the high tension required.
Re: Carbon 3D
I think the carbón3d use 0,0635 mm AF 2400 film
Re: Carbon 3D
I have receive the quote today for Teflon AF2400.
The price is €425 euros for sheet 30 x 30cm
Thickness : 0.13mm
Is this a logical price?
Thickness : 0.13mm
- Joined: Thu Oct 02, 2014 3:20 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Carbon 3D
holy crap, that's not cheap.
But i'm ready to contribute if someone wants to buy it and organize a properly detailed test.
