I'm currently using PDMS with a B9 similar setup. PDMS will not streech to an acceptable point. When I replace old PDMS coating I usually streech it to the break point and it breaks very easy. Maybe if casted with modified proportions the result will be different.
The guy in this video is using PDMS over Glass. And it works. Thinking on how to maintain PDMS over glass (for rigidity) oxygenated, it can be casted with two openings on the sides, allowing oxygen to penetrate into PDMS. The problem is that this penetration will occur only on the sides, and not at the entire surface. Attaching an air compresed source to this openings may solve the problem, but looks like overengineered. I attach some pictures. White is glass/acrilic vat, blue is PDMS and red is the openings.
Carbon 3D
- Joined: Thu Oct 02, 2014 3:20 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Carbon 3D
Would oxygen migrate all the way to the center of the vat from the openings on the sides ?
Re: Carbon 3D
don't want to sound negative but i would think oxygen would migrate at best a few microns into the PDMS,
or if it does migrate more, it would do so very slowly and the oxygen needed in the dead zone would not be replenished fast enough.
I think.
I think.
Re: Carbon 3D
More details about the 3D printer from Buffalo
Honestly, I think that would be more useful to that community to have more real tests with your own 3dprinters, using several compounds, ect ,ect , than the theories and hipotethical situations....
Re: Carbon 3D
well, before experimenting we need to think a bit
from the article:
“The Carbon3D machine uses an oxygen-permeable window to create a ‘dead zone’ (a thin layer of uncured resin between the window and the object). This dead zone guarantees the part can grow without stopping, and this is the key to the CLIP process. For our machine, we don’t use that oxygen-permeable window, but we instead use a special membrane to create that thin layer of uncured resin. There are 2 advantages of this special membrane. First, this membrane is much less expensive than the oxygen-permeable window, as it only costs about 1/100 of the price of the oxygen-permeable window. Second, this membrane is very easy to mold, meaning we can make this membrane almost any shape we want.”
According to Phife who talked to the guy, he's using PDMS. Can PDMS "create that thin layer of uncured resin." ?? First time i hear that.
Maybe the guy he's using something else on top of PDMS ? He would not have necessarily tell someone calling him over the phone, especially if he intended to patent the thing. I would not have.
WOuld it be the Titanium dioxide film as mentioned by Sid in the other post ? I asked Sid where he read about that, he did not reply yet. Titanium dioxide has some interesting properties when exposed to UV.
viewtopic.php?f=11&t=2861#p9341
from the article:
Re: Carbon 3D
Greetings Dear Hugues;
My apologies for the delayed response; actually I was out yesterday, and unplanned meeting happened with the same young student from Colorado State. Originally I learned about the Titanium dioxide from him, about one year ago, as he was inquiring about the evaporation and metallizing equipment that I used to have in my compact disc mastering business. Well yesterday I asked him about his thoughts. There can be number ways of coating. His concept is to metallize a very thin layer of Titanium over the glass sub-straight and oxidizing it.
Warm Regards
Sid
Warm Regards
Sid
- Joined: Mon Feb 09, 2015 12:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Carbon 3D
I look forward to the first person experimenting with nanostructured glass as the basin floor. It seemingly has all the benefits one needs; superhydrophobic, highly anti reflective, highly wear resistant, chemical resistant, ...
https://www.youtube.com/watch?v=0-f7NRevOAA
However currently it seems to be very limited in availability. I have yet to find a supplier who can deliver these. However these two companies at least produce this stuff:
http://www.rolith.com/applications/self-cleaning
http://www.telaztec.com/
A small sample would be enough to just test its performance.
